4 speed fitment
Old Jun 6, 2009 | 06:10 PM
theomahamoparguy's Avatar
yes they are all very similar. The only differences are the length of the tailhouse, some shifter mountings and the differences in the hemi trans compared to the others.
Early units used a ball and trunion instead of a U joint and sliding yoke . Then of course the aluminum overdrive unit, obviously made from aluminum (the case). Other minor differences did occur from year to year, some were internal, but generally speaking, they swap around fairly easy.
Old Jun 6, 2009 | 07:38 PM
Old Jun 6, 2009 | 10:34 PM
scotts74birds's Avatar
Thought that there was also something about a spline count that mattered for HP use? Once again, no expert, but I read alot.
Old Jun 6, 2009 | 10:38 PM
johnthegoalie's Avatar
thinkin with me dipstick
the difference is internal - they made actual 3rd gear od and fourth is still 1:1. the shift lever on the tranny is switched to make it all work as 3rd 1:1 and 4th od. even the hurst for the regular a833 will work on the od unit
23(i think) spline for small block and /6
18 spline for big block and hemi
Old Jun 6, 2009 | 10:56 PM
Heard that one of those spline counts strip at high hp uses. Once again, I'm not anexpert, just what I read.
Old Jun 6, 2009 | 11:27 PM
try looking at pickup trucks from the early to mid eighties
Old Jun 6, 2009 | 11:37 PM
yes it is 23 spline for the 6's and the smallblock and some of bigblocks too.
the 18 spline was used for HP use like the hemi and the 440 six pack.
the 23 spline is way more common than the 18 spline but is still very strong.
although the 18 spline is stronger. Look these guys up. www.passonperformance.com Very smart people when it comes to the 833's.
phtboy03
Jan 6, 2012 11:54 PM
jar84203
Feb 24, 2011 05:16 PM
Kalaek
Oct 28, 2010 06:03 PM
Team Gridlock
Oct 4, 2009 10:09 AM
jar84203
Jul 4, 2009 07:55 AM
