440 Mopar intake manifold
Old Feb 17, 2016 | 03:46 PM
JonathanSchnelle's Avatar
I bought a 68 Chrysler Newport with the engine apart. The intake manifold bolts up no matter which direction it's facing. Does it matter which direction it's facing? Does the numbers face the front or the rear, or does it even matter?
Old Feb 17, 2016 | 06:46 PM
Archer's Avatar
j -
That's actually an interesting question on the port and bolt geometry (been using after-market intakes so long almost forgot what the factory ones looked like - d'oh.). However, there should be bosses to mount the coil and a recess for the carb/choke thermostat, They should be forward and on the passenger side, respectively.
Old Feb 18, 2016 | 11:03 AM
Numbers toward the front if its a Cast Iron.....
Old Feb 18, 2016 | 02:31 PM
Man this was such a hassle getting the bolts lined up and I have it backwards. You think it would be a big deal to leave it like that?
Old Feb 18, 2016 | 04:02 PM
I think the Choke housing is going to be in the way of the carb linkage....
So no... I don't think you can leave the cast iron Manifold that way....
The chock coil hole should be on the passenger side. Also the vacuum port should be in the rear to hook to the power booster if so equipped.... Sorry...
Old Feb 19, 2016 | 01:23 PM
Damn. Well thank for your input.
Old Feb 19, 2016 | 02:50 PM
Way to go Bob.
Old Feb 20, 2016 | 09:23 PM
fivepoint's Avatar
Bob
If its on backwards, would you end up with 3 reverse gears and 1 forward gear?
Old Feb 21, 2016 | 07:56 AM
Bob
Way to go Bob.
....lol
Old Feb 21, 2016 | 08:18 AM
DDodger's Avatar
Some of those had the coil mount which would of course be "to front." Also some tilted the carb to level the carb. When I was in the Navy in 68 a "rich kid's" father bought him an Orange Peel 69 383 Road Runner. he bought a Weiand dual quad manifold and showed up on night, complaining "no place to mount the coil." This was before I'd ever owned a Mopar, but I pointed out that the "coil mount" was now at the rear of the manifold!!! LOL
This was at Treasure Island, CA
Dave E
Dec 21, 2013 06:24 AM
snowtrooper1966
Nov 20, 2013 06:39 PM
Fjant
May 23, 2012 03:02 AM
73Dodge400
Apr 14, 2011 11:06 AM
M1 Manifold
May 21, 2009 02:23 PM
