Aluminum Engine Parts
Old 11-17-2008 | 07:19 PM
Commando's Avatar
I was wondering what people do to aluminum engine parts.
Can you leave them be or will something happen to them, is there a special paint, or can you clear cote them?
Old 11-18-2008 | 02:54 AM
left bare and uncleaned, they can pit. I would never paint an alum part as its a good way to get rid of some heat from the motor, same with a tranny.
I have heard of people clear coating alum parts but can't remember if it was a special clear coat or not. I do not beleive it was.
Old 11-18-2008 | 07:47 AM
Commando's Avatar
I like the way it looks, and like to keep it that way, I will check out the clear coats then.
Do you remember what you used Skymynx?
Old 11-22-2008 | 03:31 PM
challenger's Avatar
hey C auto zone has a cleaner you spray on the aluminum and let sit for about five min: and rinse but i cant remember the name of it as some one else might or ill try and check when i go to the store again but i did it after a couple of years and it made the aluminum look brand new again , ill be doing it again this new season since i went to all aluminum except with the block
Old 11-22-2008 | 04:12 PM
Commando's Avatar
Did you spray a protectant or clear coat on it before cleaning it, or do you just clean it every once and awhile?
Old 11-23-2008 | 10:54 AM
challenger's Avatar
hey c i just spray it on before every season and it stays shinny all season but you can do it a few times a summer to keep it looking great , this stuff takes all the crud and dirt off and really works well , ill get the name of it if you still would like to try it
Old 11-23-2008 | 07:19 PM
Commando's Avatar
It still is new, I am just thinking about what I can do to keep it looking new.
I looked at a whole bunch of different clear coats today at the shop and they all say to spray a primer on first, don't remember if there was a clear coat primer, otherwise that defeats the purpose.
Old 11-23-2008 | 08:39 PM
challenger's Avatar
i dont think they make a high temp clear C so i would just leave it alone
it will just flake and look awfull later on down the road i think
Old 11-24-2008 | 07:58 AM
Commando's Avatar
Actually I found one that said 500 degrees, but that one I know said something about a primer. I think its a duplicolor same as the engine enamel I put on the block. Does the water pump housing and heads get that hot? I never really tried touching those parts before after running.
Old 11-24-2008 | 06:39 PM
challenger's Avatar
they dont get that hot but if you put a primer on it would it be a clear primer ?? still i wouldn't do anything to them , i never have and it always comes clean for me
Old 11-24-2008 | 07:18 PM
the heads will never get near 500 degrees
Old 11-24-2008 | 08:27 PM
Commando's Avatar
If it's not a clear primer I think that kind of defeats the purpose, I don't believe I saw any clear primers but I will look again.
uponone789
09-28-2012 04:48 AM
mvanwy02
04-15-2010 06:45 PM
plymouthrr1985
04-01-2009 04:29 AM
mbridge1
01-28-2008 10:30 PM
shadowwolf30
Cuda Specific Discussion
10-31-2007 01:55 PM
