Belt squeel with no belts on engine HELP
Old Dec 29, 2012 | 07:40 AM
my1968's Avatar
Would love to enjoy a nice drive but the noise is driving me nuts...1968 newport 383 automatic... a couple minutes of warm up and then I get a noise that sounds exactly like a loose belt. So I pull all the belts and run the motor. Same thing...seems to be coming from front of engine near crank pulley...nobody seems to know what it is....could this be a timing chain issue? Anyone had this trouble before? Engine runs smooth and otherwise ok. Help!
Old Dec 29, 2012 | 01:16 PM
blue 68 gts's Avatar
How's your oil pressure?
Sounds like a bearing is about to go.
Old Dec 29, 2012 | 04:01 PM
Gorts 5th's Avatar
Smile
Maybe your sucking air through the carb manifold gasket...
i had the same issue sounded like a belt but the air being drawn through the worn gasket was making a squealing whistle...
i never heard of a squealing engine bearing... but there is a first time for everything. if a bearing is dry it would knock.
Old Dec 30, 2012 | 12:20 AM
You're right. I know nothing.
Old Dec 30, 2012 | 08:18 AM
I would put a oil pressure guage on it and see if you have a drop in oil pressure. That would determine whether a main or rod bearing is squealing.
Old Dec 30, 2012 | 04:51 PM
Gorts 5th's Avatar
Smile
don't take that personal i'm giving some other options...
i have never had a "squealing" main bearing, if you or others have you have chimed in.
if his oil pressure was that low don't you think his lifters would be making a racket also not being able to get enough pressure to keep them primed? or do you think it's one bearing being starved for oil? pluged oil passage?
Old Dec 30, 2012 | 06:17 PM
Mr.4spd's Avatar
Do you suppose a spun cam bearing could squeal? I know a rod or main may knock, but there's no sudden loads on the cam...like explosions. Where the Hell is Roadrunner440 on this anyway?
Old Jan 14, 2013 | 09:44 AM
70Coronet's Avatar
My bet is on a air leak from under carb or intake - take a can of carb cleaner spray it around the base of carb and intake-noise will stop for a moment and car will either rev or die, --just had this exact same scenario at our shop from a older chevy pickup-thought it was alternator bearing once we ruled out belts then realized it was just a high pitch whine/whistle noise exactly like a belt coming from a air leak at the base of the carb.
Old Jan 14, 2013 | 11:45 AM
Gorts 5th's Avatar
Smile
That's what i'm talking about...
Old Jan 14, 2013 | 12:13 PM
With the belts removed and the engine nearly cold, start the engine and get it to some RPM which causes the squeal. Undoubtedly easier with an assistant.
Get a scrap of hose, fuel hose, etc, and hold one end to your ear, and probe around in the area from where you believe the squeal is coming. You should very quickly be able to find it. This method works well for exhaust leaks and some vacuum leaks.
Old Jan 15, 2013 | 06:39 PM
mikerp76's Avatar
could be the dizzy.
Old Jan 28, 2013 | 07:43 PM
moparted's Avatar
bearings
Old Jan 28, 2013 | 10:06 PM
Lack of oil to the rocker arms. Spun cam bearing could cause it I is blocking the oil passage to the rockers
Old Jan 29, 2013 | 04:31 PM
dartcuda's Avatar
I seen this problem but only after a rebuild or a new timing chain.The oil slinger was put in backward and was rubbing on the timing chain cover.
Old Feb 1, 2013 | 05:20 AM
Gorts 5th's Avatar
Smile
iv'e have heard this when a crank pulley bolt was to long and was rubbing an the timing chain cover.
Old Feb 1, 2013 | 04:01 PM
pro-tech's Avatar
seal
I agree with dartcuda, or it could be the crank seal . Do the hose trick it will help you isolate the noise. Also if there was low oil pressure the first thing to make noise would be the lifters it would sound like a singer sewing machine on steroids. Keep us posted
Old Jul 25, 2013 | 07:39 PM
mattyg50's Avatar
did you ever get the fix? mine is doing the same thing!! (383) only when it in the middle of the temp guage, all belts off, sounds like a super loose belt!! i rebuilt the motor a few years ago, probaly have a bout 3,000 miles since. i wonder if my oil slinger is on backwards? any marks to tell which way it goes?
thanks!
Old Jul 27, 2013 | 04:35 PM
Lube the dist cam. if you still have points
Old Jul 30, 2013 | 07:02 PM
mattyg50's Avatar
I found my oil slinger rubbing at the top area of the timing chain cover, and yes it was on correctly. my noise would only happen when it was at the middle temp. I heard the double roller timing chains being thicker can make the oil slinger rub?? its just my guess, but im going to install it without the slinger
Old Jul 31, 2013 | 08:43 AM
Moss's Avatar
Rod or main bearings don't squeal.
tobacjones
May 21, 2017 09:39 AM
Dave E
Mar 19, 2014 11:14 AM
thedusterridesagain
Feb 10, 2011 05:03 PM
MoparLaxer21
Oct 25, 2010 06:16 PM
MoparOnly
Sep 6, 2010 03:19 PM
