Torque specs
Old Aug 1, 2013 | 10:37 PM
70newport's Avatar
Torque specs
So my 1968 Newport just got new leaf springs, new shackles, new bushings, new gears, u bolts, shocks etc. basically every thing in the rear end replaced. Now I have spent 3 weeks + trying to find torque specs for all the bolts and can not come up with anything so I did what seemed right and am hearing a lot of creaking from the rear currently.
Any ideas as to what everything back there should be torqued to would be great.
Thanks,
Gary
Old Aug 1, 2013 | 11:23 PM
moe7404's Avatar
i have a 1967 chrysler / imp. factory service manual. it should be the same. all numbers are FT LBS. the upper bolt nut at 70 may be to high. so look at its size, and adjust torque so you dont brake any thing. the track bar is most likely imperial only.
rear springs
center bolt nut................10
front hanger nut..............30
pivot bolt or nut..............125
rear hanger....................30
shackle nut....................35
"U" bolt nut...................45
shock absorbers
front lower bolt nut..........50
upper shaft nut...............25
rear lower stud nut..........50
upper bolt nut.................70
track bar
lower stud nut.................50
upper mounting nut..........40
side rail bracket nuts........30
Old Aug 2, 2013 | 09:42 AM
70newport's Avatar
moe7404 THANK YOU THANK YOU THANK YOU! So much appreciated.
sweeperking
Feb 28, 2011 03:59 AM
jdewoskin
Aug 7, 2010 02:14 PM
beep1969
Dec 19, 2009 03:16 PM
Mar 18, 2009 06:33 PM
got2mopars
Sep 22, 2007 05:44 PM
