A body dash swap
If you are talking about the whole thing, Door to Door, then yes, it will. If you want to take the instrument cluster and just replace it, then no. You have to find a Ralley dash for the cluster to fit.
j
j
Guest
Posts: n/a
a body dash
Thanks for the clarification, I wasn't specific with my question. I was asking about swapping the instrument cluster only and wasn't sure if it could be done. How difficult is a complete dash swap ? Bolt on ? I imagine a complete ralley dash is hard to come by and extremely expensive if you can find one.
The windshield needs to come out for a complete dash swap. You will need the entire frame for the ralley cluster to work. You will also need the ralley wiring harness for underdash. You can use the frame from a 67-69 Barracuda, or a 70-71 Duster 340 or the 71 Demon340. The 67 B-Cuda frame does not have the pad (inset) for the VIN tag.
Morrigan_Aria
06-26-2009 08:54 PM
