c-body rotor identification please
I have an old dic brake set-up from an early 70's Fury but do not remember the year of the donor. Can anyone I. D. these for me?
I need to know if they are the two piece rotors so I can get replacements. Looks like two piece to me but I want to be sure nefor I spend anything on 'em. They look pretty beafy so I might be able to get em turned but still want to know just what I have. Thank you in advance.
boogie
Problem solved I have been informed that these are indeed the 69 to 72 two peice rotors.
Looks like I have some info for anyone else wondering about this.
Here is what I have learned.
The difference between the 69/72 and the 73 is the diameter of the spindle. Measure the spindle diameter.
The new rotors are all one peice but you need to know the spindle size.
From the Rockauto site:
1972 and earlier Inner bearing ID=1.25", OD = 2.32"; outer bearing ID = 0.75", OD = 1.78"
1973 Inner bearing ID=1.377", OD = 2.36"; outer bearing ID = 0.865", OD = 1.811"
Also, Rockauto has Raybestos 1972 and earlier rotors for $112 each.
boogie
