Cant get new (340 equivalent) valve springs on intake valves
Old Apr 1, 2020 | 05:18 PM
76d100's Avatar
Hey so I’m new to this forum. I’ve got a 76 d100 and I just put a summit k6901 cam kit in a stock 318. I’ve already broken it in with the stock valve springs. I got trick flow springs, I can’t remember the part number but I think there a little stronger than stock 340 springs, and have a smaller spring inside.Then I have 744-16 comp retainers on top, which have a 7 degree lock. Well I got a spring on the exhaust side with no problem. But the intake side is a different story. It feels like I can’t compress the spring enough, even tho I can somewhat see the grooves on the valve. I recently bought some new keepers that are 7 degree, but i still can’t get the keepers in. I don’t know if this helps but I’m using a harbor freight spring compressor. Idk what to do.
Old Apr 2, 2020 | 10:07 AM
Drag Pak's Avatar
Do the new inner springs fit over the valve seal boss?
Old Apr 9, 2020 | 06:44 PM
76d100's Avatar
Hey srry I just checked, they do clear. I found .60 shims that were under the factory springs. Dodge didn’t put shims in from the factory did they?
mizzou580
Mar 11, 2016 06:41 PM
74Runneer
Oct 17, 2015 10:32 AM
duster3
May 31, 2013 10:07 PM
xjonathanx
Jan 30, 2010 09:36 AM
67rockabillydart
Apr 14, 2009 01:11 PM
