Clean Intake
Old Mar 21, 2014 | 05:31 PM
mrzods13's Avatar
Clean Intake
What can I soak my intake in it has black deposits in it can't get it out. I was going to buy a 5 gallon pail of brake cleaner and just soak it in that for a while.
Old Mar 21, 2014 | 06:55 PM
Archer's Avatar
mr -
Cast or aluminum?
Old Mar 21, 2014 | 07:45 PM
moe7404's Avatar
if its baked on carbon, water will loosen that. it does on my smoking pipe. a little heat might help
Old Mar 21, 2014 | 08:36 PM
mrzods13's Avatar
Cast and I was hitting it with the torch before back and forth and it was coming off a little but it is been baked on, it's been on there for a while. Thinking of hot tanking it, might be cheap at the local machine shop can't see it being more than $50
Old Mar 21, 2014 | 08:55 PM
moe7404's Avatar
build a steel box on top of your bar-B-Q and heat to 300- 500 F.
Old Mar 22, 2014 | 04:55 AM
have the local machine shop hot tank it.... I had a friends 2.2 ply spun a rod brg.
WHAT a mess to get everything clean. Looking back I should have taken it to the machine shop I spent hours & hours cleaning everything
Old Mar 26, 2014 | 07:49 AM
mrzods13's Avatar
It is gonna be $25 for glass beading and hot tank not bad at all.
Old Mar 26, 2014 | 02:08 PM
pro-tech's Avatar
Moe you are like my brother...I put all my parts in an old Bar-B que and turn it on high for an hour or two...When the part comes out paint,carbon,grease, whatever just brushes away and it is clean as a whistle...I do that on heads intakes small brackets etc...it is like having a hot tank/box which alot of machine shops dont use hot tanks anymore...They have a big hot box and clean part in this fashion so the by-product is ash and much easier to dispose of...Bill
Old Mar 26, 2014 | 02:11 PM
Bill is full of hogwash... He takes them to work and uses the trans guys parts washer.....lol
Old Mar 26, 2014 | 02:16 PM
Mr Belvedere's Avatar
Throw some ribs in there with that intake!!
Old Mar 26, 2014 | 02:23 PM
pro-tech's Avatar
They dont do it anymore to many Envromental issues...I dont work anymore so I dont have the access I use to...But the local engine shop here does it the way I was saying in a big Hot box type thing and all the debris falls into a big draw on the bottom that is dumped into a dumpster and is evriomentaly friendly...Thats where I got the idea and all the debris falls into a can under the bar-b que...it works for me...The only issue is it does smoke for a while until the grease burns off...I do have a question though is hogwash where you take a bath/shower....Now that funny I dont care what side of the country your from...LMAO....Bill
Old Mar 26, 2014 | 02:24 PM
moe7404's Avatar
is pro-tech my long lost bro? ill bet you soak the out side of a carb for a couple of days with WD-40 to loose the dirt before you final clean it. and / or should we star a talk about marvel mystery oil?
Old Mar 26, 2014 | 02:28 PM
I just spit coffee all over my screen.....
Old Mar 26, 2014 | 02:34 PM
Some say Vinegar work well if you let it sit.... But I have not tried it!
Old Mar 26, 2014 | 02:36 PM
How about a few gallons of Coca cola?
Old Mar 26, 2014 | 02:46 PM
No...That's old school VHT for traction...
Old Mar 26, 2014 | 02:50 PM
pro-tech's Avatar
The ole oil of wintergreen great stuff use it all the time...If you drink it it keeps you regularWD40 is great stuff too. It even smells good enough to drink......Have you ever heard of WD41???Bill
Old Mar 26, 2014 | 02:55 PM
pro-tech's Avatar
Now why didn't I think of that??? Thats multi tasking right there folks...Now Thats some funny s#!t right there...You might be a Red-Neck if your intake and Ribs are done at the same time......Bill
Old Mar 26, 2014 | 02:57 PM
: laugh::l augh:
raycan2
May 1, 2013 04:34 PM
Aug 21, 2010 07:24 PM
sgp7679
Aug 11, 2010 05:23 PM
Zach8200
Nov 6, 2008 04:55 AM
jane1043
Jun 12, 2008 10:38 PM
