Diff pinion nut, etc., removal for shade tree mechanic
Old Mar 6, 2020 | 02:56 PM
74MAX360's Avatar
Question Diff pinion nut, etc., removal for shade tree mechanic
Have to replace pinion seal.....
First.... what is the best (or acceptable) way for a shade tree mechanic to remove a pinion nut from the 8 3/4 489 diff -and how can I keep the pinion yoke (?-not flat flange) from moving?
Second.... best (or acceptable) way to remove pinion yoke.
Third... If I put a socket and breaker bar on the nut -wheels on the ground and parking brake on -and turn the pinion as if in drive/forward then as if in reverse, how should it act?
Should there be any play? I can wiggle it forward and reverse (not in and out) just a tad by hand, but with the socket and bar I am hearing a lot of things going on in there between forward and reverse before movement stops -I'm a newb and don't know what is normal
I heard someone say the parking brake can be used as resistance while removing pinion nut -but that sounds hinky.
Old Mar 6, 2020 | 07:58 PM
John Van's Avatar
Hello!
First: Socket/breaker bar on nut and a pry bar to hold flange in place
Second: pinion stays, with puller take off flange, remove seal and replace
Third: I highly recommend getting a repair manual, there are small steps also, like counting number of threads on pinion before removing the nut
Good luck, john
Old Mar 6, 2020 | 08:06 PM
74MAX360's Avatar
thanks! i totally forgot to check my TWO repair manuals -duh
greasemonkey
Nov 15, 2017 10:13 AM
roger.bell
Jul 2, 2015 10:20 AM
Coronet 500
Jul 17, 2013 05:13 AM
mopar777
May 5, 2011 07:59 PM
