Do I Have To bench Bleed?
Old May 30, 2009 | 05:12 AM
3x2v's Avatar
Junior Member
I just installed a new brake system on my 70 GTX (4 wheel drum non power) I haven't put fluid in yet, but I didn't bench bleed the master. Is it absolutely necessary? can I do it in the car? what are the ramifications. I don't want to take the master back out if I don't have to.
Old May 30, 2009 | 05:42 AM
Polaradude's Avatar
If you have a mityvac you can suck fluid from the master to each bleed screw or reverse fill the brake system from the bleeders up. But I don't think you have to bench bleed, it will just take a little longer the usual way. Welcome to the forum.
Old May 30, 2009 | 06:39 AM
craveman's Avatar
Senior Member
you can also bleed the master cylinder by unscrewing the brake lines then having somebody push it in in case you dont have the bleeder.i always force fluid up from the bleeders that way it pushes out all air in the system.
Old May 30, 2009 | 09:48 AM
You can bleed the master while it is int he car like the guys said. After that, you can gravity bleed the rest, just keep an eye on the level of the fluid.
Old May 30, 2009 | 11:19 AM
you do not have to bench bleed, but it'll make the process go quicker if you do
Old May 30, 2009 | 01:45 PM
Not to mention easier because it only takes one person, not two.
Old Jun 24, 2010 | 08:29 AM
JMN's Avatar
JMN
Junior Member
bench bleeding is advisable. But I have a question. I am installing a disc brake kit w/power booster in my 1969 Coronet. Between the booster and master cyl. there is a rubber conical-shaped insert that seems to fit the opening. Does this stay in place or was it just for shipping purposes? Also the new proportioning valve is not exactly identical to the old one. Pretty close tho'. If it is not exact do I need to re-plumb or call the manufacturer and find out if it the correct one?
Old Jun 24, 2010 | 07:17 PM
sweeperking's Avatar
Yes and Yes
mopar nate
May 7, 2010 08:53 PM
mike639
Apr 1, 2009 07:33 PM
mopar nate
Mar 20, 2009 01:39 PM
fpereira23
Feb 11, 2009 05:57 PM
440roadrunner
Jan 25, 2008 11:48 PM
