Dumb Holley power valve question
Gents -
When you guys replace a (Holley DP) power valve either to change size or "because you have to..." do you:
1. Leave the carb on the manifold and disconnect the inlets and bowl/plate and make a mess in the process ...
or
2, Remove the carb from the manifold first, drain, then take it apart.
I've done it both ways and not sure which way I like better
or
I would leave carb on manifold.Use a small bowl or anything you could drain the fuel bowl into.Remove one of the lower fuel bowl screws and 90% of the gas will flow out.Then lay a rag under the fuel bowl and remove the other 3 screws
Same proceedure I use when doing a jet change on my 2 holleys
mslisaj
Sep 19, 2014 11:14 AM
