Dumb Holley power valve question
Old Jun 30, 2010 | 07:20 PM
Archer's Avatar
Gents -
When you guys replace a (Holley DP) power valve either to change size or "because you have to..." do you:
1. Leave the carb on the manifold and disconnect the inlets and bowl/plate and make a mess in the process ...
or
2, Remove the carb from the manifold first, drain, then take it apart.
I've done it both ways and not sure which way I like better
Old Jun 30, 2010 | 07:23 PM
blue 68 gts's Avatar
Just pull the carb off and make use of a work bench...
It's only 4 nuts holding it on, a vac line, couple cotter pins...
Plus the gas getting all over the manifold... not my idea of fun.
Old Jul 3, 2010 | 10:49 AM
HEMI-ITIS's Avatar
I would leave carb on manifold.Use a small bowl or anything you could drain the fuel bowl into.Remove one of the lower fuel bowl screws and 90% of the gas will flow out.Then lay a rag under the fuel bowl and remove the other 3 screwsSame proceedure I use when doing a jet change on my 2 holleys
Old Jan 17, 2012 | 08:24 AM
Archer's Avatar
Guys -
Just catching up on a few old threads.
Yup, plastic bowl under the fuel bowl and a rag around the base of the carb; it's a pretty quick swap.
Tks
Old Jan 18, 2012 | 05:48 PM
scotts74birds's Avatar
Good job. My attempt back in the day, of using half a beer can, and bumping the electric choke wire, didn't go so well! Good thing it was a Cheby!
mslisaj
Sep 19, 2014 11:14 AM
crwchf16
Feb 1, 2012 10:53 PM
olibass1
Oct 6, 2011 11:48 AM
67gtxclone
Feb 14, 2010 08:36 AM
MrOldart2U
Oct 13, 2009 04:29 PM
