EASIEST WAY TO GET OIL PAN OUT??
Old 11-10-2007 | 05:44 PM
The last time I was under a '69 (383) RR was about 1970. I don't remember having to lift the engine. Those cars SHOULD have a windage tray, IE two pan gaskets. Are you sure the pan isn't still glued to the tray? I don't remember if I had to disconnect the steering linkage or not, but I certainly don't consider that a real big deal. You need the appropriate puller to knock loose the tapered ends, I used to use a "pickle fork." However, those are hard on the rubber seals!!
chezhed
08-08-2011 07:09 PM
tahoeskier
06-18-2011 06:59 PM
MarkyMark12345
04-10-2009 06:43 PM
dzltd02
10-28-2008 08:25 AM
robertoil
01-25-2008 05:34 PM
Quick Reply: EASIEST WAY TO GET OIL PAN OUT??
