engine &tranny removal
Old Feb 26, 2012 | 12:56 PM
fenomenalkatt's Avatar
Red face engine &tranny removal
removing a 225 and 904 from a67 dart is it easier to remove them as a single unit
Old Feb 26, 2012 | 01:03 PM
i yanked the 318/727 as a single unit and didn't find it too difficult. just watch the nose cone of the tranny when it comes out. the reason i did it that way is because i'm hoping to freshen up the 727 as well as the engine, so i figured i'd yank 'em both.
Old Feb 26, 2012 | 01:26 PM
this will be a virginal attempt lol so hope all goes well thx
Old Feb 26, 2012 | 01:56 PM
fivepoint's Avatar
If you have an extra front driveshaft yoke to slip on the output shaft, it will prevent tranny fluid from leaking out when the trans is tilted that far back.
Old Feb 26, 2012 | 06:35 PM
Use an engine tilter and you will do it safely.
Old Feb 26, 2012 | 07:14 PM
Boooooooooooring.
j/k. He's right.
Old Feb 27, 2012 | 11:16 AM
I would do it separately ! The 6 is much longer & may be a problem getting clearance
Old Feb 27, 2012 | 04:44 PM
Originally Posted by Skwerly
Boooooooooooring.
j/k. He's right.
Also jack the rear of the car up in the air as high as your jack stand will go. I did it four times with a 318 and an 833 OD tranny.
Old Feb 27, 2012 | 05:02 PM
Old Feb 29, 2012 | 09:30 AM
excellent advice with jacking the back of the car up. when i was pulling the engine out of my fury, we must have jacked the front and back six times, depending on where we needed the car lifted.
lowering it makes it look cool, but very difficult to get under.
86Dodgeman
Nov 2, 2013 08:22 PM
GTX-440
Sep 2, 2012 02:28 PM
lukey
May 3, 2010 04:52 PM
jvfante
Apr 28, 2009 10:55 AM
Captainkirk2931
Jan 6, 2009 11:37 PM
