ignition help !!
Old Oct 16, 2011 | 02:51 PM
rc-ltu's Avatar
ignition help !!
ok so installed an EZ wiring harness on a 73 charger with an MSD 6AL box and everything works great except it wont turn on it sounds like the power is getting cut out or something because i turn the key to start and it starts then i let it go and it returns to ON position and it turns off like if the power get cut off i connected everything correctly according to the manuals and such but im guessing the ignition wires there must be something that needs modding for it to work i just dont know what ??
Old Oct 16, 2011 | 04:35 PM
You don't have something wired correctly One bad thing most the aftermarket wiring outfits do, is to NOT make allowances for the special way that Mopar wired their start/ ignition circuits.
It is IMPORTANT that you understand how they work
Do you have a wiring diagram for the ORIGINAL car?
Here's how the ORIGINAL ignition circuit works
Diagrams from "My Mopar:"
http://www.mymopar.com/downloads/197...etChargerA.JPG
http://www.mymopar.com/downloads/197...etChargerB.JPG
Look at diagram "B" and find the ignition switch connector. Unfortunately, those diagrams do not identify the larger from smaller gauge wires
Originally, the largest RED going to the switch connector was hot battery coming from the ammeter circuit. Must be hot at all times
In "run" TWO circuits are live, the large BLACK which feeds the switched power out to the fuse panel,
and "ignition run", sometimes called "IGN1", which is DARK BLUE
In "start" the only "live" wires are two......
YELLOW feeds to the start relay and engages the relay IF you have the clutch depressed --on stick cars with a clutch safety switch, or if the auto trans is in park or neutral. The NSS supplies a ground on the other terminal of the start relay
BROWN feeds hot battery power to the ignition during start. This BYPASSES the ballast resistor, sometimes called "ign2"
When you hook up an MSD with no ballast resistor, you MUST jumper the brown and dark blue together to get the car to start and run.
I'm guessing you did NOT run a wire out from the ignition "run" or "DARK BLUE"
Old Oct 17, 2011 | 05:39 PM
rc-ltu's Avatar
ah man perfect, i just jumped a wire from the brown to the blue and it started right up awesome .
a.johansson84
May 27, 2012 03:30 AM
Tiretrack
Jul 10, 2010 08:14 PM
71satellite
Sep 6, 2009 05:53 AM
GMdude
Jul 9, 2009 04:42 PM
1980b100van
May 2, 2008 09:53 AM
