Installing valve springs on a 74' 318...
Old 04-06-2009 | 10:39 AM
67rockabillydart's Avatar
ok, i need help.. i bought a set of edelbrock valve springs to go with my cam.. the cam is in but the valve springs, im having a hard time understaning the instructions... does any one have better instructions or experience?? i really need help. thanx...
Old 04-06-2009 | 03:01 PM
69Fury3's Avatar
As long as the heads are off the car it is relatively simple. Get a good spring compressor, compress the springs, remove the locks and retainers, release the compresser pressure, remove the springs, install new springs retainers and locks.
Old 04-06-2009 | 03:26 PM
Commando's Avatar
What's the part number, Edelbrock has all the instructions on their website, I will take a look at them.
Old 04-06-2009 | 06:28 PM
the part number is 5877.
Old 04-06-2009 | 07:38 PM
Commando's Avatar
You're right there really aren't instructions there, the pictures I think are more helpful. You'll need a spring compressor and just do what 69Fury3 says.
Old 04-06-2009 | 10:48 PM
I was going to do it with the heads still on... but will it be easier to take the heads off??
Old 04-07-2009 | 06:47 AM
Commando's Avatar
There's a different tool depending on which way you do it. The tool I am most familiar with for this looks like a pair of tongs and is used with the heads off.
It's your call on which way to do it. If you pull the heads off you can put a new head gasket in, you probably don't know the condition of the old one, and you can also look at the condition of the cylinders and the pistons.
Old 04-07-2009 | 08:47 AM
well i've taken off the heads so many times now... it's got a new gasket, the pistons and cylinder walls are fine.. i cleaned everything... i'll see if i can find the tool to get them off with the heads on then... THANX A LOT GUYS.. you have been REALLY BIG help.
Old 04-08-2009 | 05:26 AM
cudaneil's Avatar
Originally Posted by hypermite
Don't forget to pressurize the cylinders with compressed air, or the valves will fall in, when you pull the locks off!
Or put some rope in there through the plughole and pushup the piston to
the top,that works too ! Dont forget to leave some rope hanging out
to pull it out again. (Basic i know but it works)
Old 04-08-2009 | 05:47 PM
you pulled the head off right?
Old 04-14-2009 | 09:43 AM
OK, i got it done.. i bought a tool from o'reilly and the old valve springs came right off.... thanks again guys...
Old 04-14-2009 | 02:11 PM
no problem
any more questions, just ask away
74Runneer
10-17-2015 11:32 AM
duster3
05-31-2013 11:07 PM
jane1043
05-08-2008 08:11 PM
Wonsley69
02-22-2008 05:39 PM
Quick Reply: Installing valve springs on a 74' 318...
