Mapping my DIY Electronic Ignition :)
Got my distributor fixed, now mapping the ignition timing vs. RPM vs. load using the handheld trigger.
I can retard/advance the ignition timing at every 300rpm increments (or 500rpm increment if you wish) (15 steps i.e. 0 - 4500rpm) vs. load (throttle). Here is a picture or two :
and here ive also fitted the 3-3/8" Sun Pro Tacho on the column (can't fit on top, no clearance)
Syed
Malaysia
Syed
Malaysia
1966DartConvertible
May 13, 2012 08:11 PM
theaspenator
Jan 30, 2008 06:30 PM
