Need to find axle parts
Anyone know where I can get a replacement stub shaft and castellated nut for a 2001 Ram 1500 4x4 with a Dana 60 front axle? I had to heat the original to get it apart and want to replace it with something that still has the temper in the metal. The OEM part numbers are:
Stub Shaft 05015138AA
Axle Hub Nut 04746773
Yeah because I don't think Dodge would ever install a 1 ton front end into a 1/2 ton truck. I'm sure that is more a long the lines of a D44 or whatever Dodge decided to install in the front end of the Ram trucks.
That is not entirely true. Dana 60, dana 70 and dana 80 are all 1 ton axles. what you have for axles in a 3/4 ton truck all depends on what youhave for a motor. All of the gas V8 3/4 ton truck that I have seen and read about had a D44 or 8.25 front axle with a D60 rear axle. All the diesel 3/4 ton trucks had D60 ball joint front axles and D70 rear axles. At anytime though, someone could have swapped them out. This being a 1/2 ton truck, I would say that he has a D44 or 8.25 front axle and a 9.25 rear axle.
