Oil Leak Problem
Old Oct 22, 2008 | 06:45 PM
Oil Leak Problem
Ok, me and my dad did a rebuild on our 440 motor. After we got it working, we noticed a leak on the rear block seal. I'm not sure what it is called, but it isn't the rear main seal, its behind it. The rear block seal?
Anyway, even my local speed shop was worried about this. The new seals aren't as good as the original ones. The original one is a fabric that covers the whole opening.
Does anyone know where to find this seal?
Can the oil pan be taken off of my 67 GTX 440 without taking the engine out of the car?
Old Oct 23, 2008 | 03:06 AM
I'm not sure if the job can be done in the car, but the part that you are looking for is called a rear main seal. Felpro and Mr Gasket makes some good ones that I have used on the jeep 4.2L
Old Oct 23, 2008 | 07:16 AM
Commando's Avatar
You are talking about the piece that holds the crank in on the back end of he block.
78 is right about the seals, I got a set from Mr Gasket, haven't used it yet, but it looks to be real good.
Old Oct 23, 2008 | 08:57 AM
when installing a rear main seal you need to take extra caution that you do not cut the gasket at all, even if its a sliver. The smallest piece that gets cut off when installing it will cuase it to leak, believe me. I've been there and done my share or cursing.
Old Oct 23, 2008 | 12:17 PM
Not the rear main seal
there is another seal behind the one that holds the crank in place
Old Oct 23, 2008 | 02:28 PM
The rear main seal is it to my knowledge. When I built my 383 BB that was the farthest back seal there was. Can you take a pic of what you are talking about?
Old Oct 23, 2008 | 02:29 PM
Commando's Avatar
The only other one besides that is the one behind the cam.
Perhaps a picture would help.
Old Oct 23, 2008 | 02:34 PM
ill try to take a pic and post it later
thanks for your help
Old Oct 23, 2008 | 03:31 PM
ef8340's Avatar
Senior Member
would it be a rope style seal? if so i think napa might have them
Skynyrd
Sep 10, 2014 05:24 PM
dzltd02
Oct 28, 2008 08:25 AM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:34 PM
