Power steering Question
Old Jun 15, 2016 | 11:59 AM
ron john's Avatar
Question Power steering Question
I have a 1972 Dodge Swinger with a Federal P.S. Pump, I am trying to drop the pressure to firm up the steering feel, Is it possible to put a adj. Hydraulic pressure valve in the high pressure line to drop the pressure?, The relief valve on the Fed. Pump is hard to get to?
Old Jun 15, 2016 | 08:28 PM
Don't have it handy, there is an article about shimming the pressure relief valve in the pump
Ok I went and got it here http://www.moparaction.com/Tech/beep...WN-re-v1.4.pdf
Old Jun 20, 2016 | 07:55 PM
ron john's Avatar
Has anyone took a Federal pump apart to shim the pressure valve?, Do you have to remove the pulley our can you acess it by removing the reservoir only?
Old Sep 7, 2016 | 11:00 AM
60jerry's Avatar
Yes, I did that operation a few months ago. Mine's a '66 Dart GT, slant six. I got a federal pump and built brackets to fit. The pressure valve is relatively easy to remove. Disconnect the steel line and then use a big wrench (one inch or thereabouts, don't remember) and remove the pressure valve. Adding shims reduces steering assist. I resized some washers to use as shims. Removing the pump from the car makes this easier.
Jerry in Denver
65Monaco
18
Jan 7, 2015 09:52 PM
cvon
Apr 12, 2010 09:49 AM
bgreene30
Nov 20, 2007 12:49 PM
bgreene30
Nov 10, 2007 11:07 AM
patricklyle77
Jun 14, 2007 10:42 AM
