Rebuilding a 1987 Dodge D150
Old Dec 4, 2010 | 02:41 PM
itaylor6438's Avatar
All, I'm wondering if I can get some feedback on a rebuild. I have an '87 Dodge D150 from my grandmother I'd like to rebuild. It still has the stock 318 and tranny, but the motor is done. I have a rebuilt 318 out of a 1974 Dodge Dart. Motor is perfect. Will the '74 318 match up with the '87 stock tranny? If not, which tranny would I need? Also, I do have a 1987 Dodge Ramcharger, painted her General Lee Orange. She is a beauty. Thanks.
Old Dec 4, 2010 | 08:23 PM
The only caveat I can think of, is that some engines, originally destined for auto trans cars or trucks, did not have the bore for the pilot shaft of a STICK TRANSMISSION finished to size and depth. It used to be common to cut a little off the transmission shaft rather than fooling with the crank, and nowadays you can get pilot bearings that fit the large "converter bore" of the crank.
If you the D150 is an auto trans, just use that
Old Dec 5, 2010 | 06:12 PM
theomahamoparguy's Avatar
Grandma had a D150? Wow, I bet it's in pretty good shape. Engine shoud slide in with no problems. Use the exhaust manifolds and the motor mounts off the original truck motor. At least they're easy to get parts for,a ton of them in the scrapyard out here.
Good-luck.
Old Dec 5, 2010 | 07:39 PM
I was thinking of throwing a pair of headers on her with some flowmasters. She has the 80s exhaust, but all that can go now that she is historic.
Old Dec 5, 2010 | 07:41 PM
Meant to say 80s emissions...
Old Dec 6, 2010 | 03:01 AM
440roadrunner is correct about swapping the motors. As long as both vehicles had automatics or both had manuals, they the motor from the Dart will drop right in.
Check with your state emission laws before you start to pull everything off. Some states are starting to crack down more and more now to make sure that vehicles are "emissions safe".
Old Feb 24, 2011 | 09:21 PM
wickedshortbox's Avatar
hello i have a1982 which i have been rebuild for a couple years now iam just wondering if the shift linkage from the 904 is the same as the 727 if so could you please let me know
Old Aug 25, 2014 | 09:37 AM
Dodge_Ram_Runner95's Avatar
1987 Dodge D150 Rearend
Hey ya'll Im in the process of restoring my 87 D150 and i was wondering does anyone know where i might be able to get a posi rear end that would fit my truck. Its the stock 318 SWB pick up. im wanting to turn it into a show truck and wanted to put a posi on it just not sure where to find one or what rear end would fit. if anyone could let me know i'd appreciate it. thanks ya'll
Old Aug 25, 2014 | 09:08 PM
You will need to adjust it, should work fine
lboggie
Aug 10, 2011 03:23 AM
Bandit
Jul 7, 2011 05:33 PM
Minnesota Guy
Nov 27, 2010 05:17 AM
hipowerv10
Oct 19, 2010 06:12 PM
hellzombiex
Mar 13, 2009 02:45 PM
