Reverse?727
Old Dec 26, 2008 | 03:33 AM
BuckNeccid's Avatar
Drop the oil pan, and check the flat bar that hold the reverse band in place against the case. Some have a tendency to pop out of place and there ya go, no more reverse. I can't remember for sure, but it seems you can put it in place without dropping the valve body. I bought a really nice '70 Charger cause of this problem for $300 once... (Course that was back about 1990)
Old Dec 26, 2008 | 08:36 AM
The 727s are really good trannies. I'd check out what BuckNeccid said and go from there. If there is nothing then I would call up the tranny shop and see what they can do for you. Most have a 12 month, 12,000 mile warrenty.
Old Dec 26, 2008 | 05:58 PM
Commando's Avatar
I just got the book on the 727 will let you know if I find anything helpful for you.
Old Dec 31, 2008 | 08:01 PM
blue 68 gts's Avatar
There is a chance that the band might be breaking.
Old Jan 1, 2009 | 07:37 AM
Commando's Avatar
I just checked the 727 manual, and it says to check fluid levels, fluid pressure, check for air in system, adjust low and reverse band, valve body malfunction, or a broken planetary gear.
Old Feb 3, 2009 | 01:56 PM
Redvan, how did it turn out?
hellzombiex
Apr 18, 2014 09:13 AM
crwchf16
Dec 12, 2009 05:44 PM
Airkiller
Sep 21, 2009 07:38 PM
sgp7679
May 25, 2009 08:07 AM
