starting problems 73 plymouth satellite
Old Jul 24, 2010 | 06:46 AM
prive81's Avatar
Junior Member
when i turn the ignition nothing happens; however, when i cross the terminals on the starter relay with a screwdriver the engine cranks and starts. i've changed the starter relay but that hasn't solved the problem. what do i do next?
Old Jul 24, 2010 | 06:13 PM
1966sportfury's Avatar
A.K.A Bob Dodge
you changed the relay on the fire wall.,...all connections are good must be in the switch is all i can figure
Old Jul 25, 2010 | 05:33 AM
prive81's Avatar
Junior Member
thanks. checked the neutral safety switch and noticed the wiring connector that fits over the switch is cracked. perhaps that's the problem. don't know if that part is available at auto parts stores, though.
Old Jul 25, 2010 | 06:16 AM
jdewoskin's Avatar
Yearone.com has them for about $15. I had a similiar problem in my 1972 Charger.
Jake
Old Jul 26, 2010 | 03:47 AM
prive81's Avatar
Junior Member
thanks, jake. will see if that solves the problem.
Old Aug 3, 2010 | 06:50 AM
crwchf16's Avatar
Did you get this figured out? If not then your best bet is to find a wiring diagram and a multimeter plus a rtest light and start making sure you're getting current where you need it. Just a guess but I'm thinking you have a bad wire or plug somewhere. If not that then the key switch itself may be shot. Good luck
xvodysseusvx
Jun 25, 2018 04:38 PM
mr_Sancho1324
Feb 3, 2011 09:05 PM
MMMichael
Nov 29, 2010 07:10 AM
alsparl
Jul 7, 2009 03:39 AM
Evnas
Apr 13, 2009 11:01 PM
