Window out of alignment on 72 Duster
Old 04-30-2012, 05:10 PM
DusterDude88's Avatar
I noticed last night after cruising around in my 1972 Plymouth Duster that when I went to roll my drivers side window up, it was extremely hard to roll the window up. I rolled it up as far as I could and shut the door, only to see that the rear of the window, on end with door handle, lacked 1.5 to 2 inches of completely being rolled up.
So clearly, I'm sure that there's a misalignment somewhere but I just don't know what to do to correct it. I tried adjusting the division track by turning the bolts on the bottom of the door and had little luck but not much and the window is still hard to roll up and down.
What would be the correct method to correct the misaligned window? Any help would be greatly appreciated, I've only worked with one other jammed window and it ended up getting broke(it was in a mack truck though so no major loss) but I dont want to break my window.
Any help would be greatly appreciated!
Thanks,
Jon Preston
Old 04-30-2012, 07:27 PM
It is more than an adjustment.. Take the door panel off, maybe one of the plastic clips for the4 window regulator arm broke ??
Old 04-30-2012, 08:05 PM
MrOldart2U's Avatar
yeah sounds like a roller issue to me also. You will need to remove the door panel to access...
10-04-2012 11:09 PM
72bird
08-04-2012 09:58 PM
mfleck_us
09-11-2010 06:27 PM
sgp7679
06-14-2009 04:19 PM
johnny4915
11-29-2008 05:05 AM
Quick Reply: Window out of alignment on 72 Duster
