05 ram 1500 5.7 hemi starting problem
Old Sep 18, 2017 | 11:30 AM
matt1967's Avatar
Recently the fuel pump on my 1500 crapped out and I had it replaced. On cold starts the truck seems to be fine, but when warm starting, the truck likes to crank for a while... I had my ear to the tank and the pump is loading up.. could this be a bad pump??
Old Sep 18, 2017 | 08:00 PM
Best thing to do is perform and fuel pump pressure test procedure on the system and make sure it is acting rite.
Just my 2 cents
Old Sep 21, 2017 | 03:18 PM
carcomputerexchange's Avatar
Former Sponsor
Pressure test would be my first test
I'd test to see if the pressure was ok on the fuel pump also.
Old Sep 21, 2017 | 07:03 PM
Drag Pak's Avatar
I found that a dirty/faulty intake air temperature sensor will cause hard(lots of cranking) starting. You may wish to take it out and clean it with a deluge of aerosol sensor cleaner.
Old Sep 21, 2017 | 07:51 PM
Mite look at the service intervals.... The Spark plugs might need to be changed ????
Old Sep 26, 2017 | 06:37 AM
matt1967's Avatar
Mite look at the service intervals.... The Sparkplugs might need to be changed ????
I'm going to be replacing the plugs to see if it helps the problem... everywhere I look I get different answers so I want a third opinion. Should the plugs be gapped at 40 thousandths??
Old Sep 26, 2017 | 05:46 PM
Set them at 0.045 gap...
Correct me if I'm wrong? But I think the service interval is 30,000 miles for spark plugs for those engines ???..
Hope that helps your issue...
Old Sep 27, 2017 | 09:49 AM
matt1967's Avatar
The service interval is every 25 to 30,000 miles for those engines.. Thanks for the help
Old Oct 3, 2017 | 01:59 PM
homebrood's Avatar
Difficult hot starts could be a starter issue drawing too many amps and needs replaced.
But if it's cranking normally then probably not...
Old Oct 4, 2017 | 02:19 PM
I would agree... Alternators will cause big issues now days... Grounds also...
Old Oct 4, 2017 | 02:20 PM
Have the crank sensors been checked?
And this all started after the fuel pump change? Rite?
philsbrandt
Apr 1, 2015 01:51 PM
fcpnative
Sep 1, 2010 08:48 PM
1 Bad Mirada
Jul 7, 2009 08:01 PM
johnthegoalie
Jun 30, 2009 01:45 AM
johnny4915
Nov 29, 2008 05:05 AM
