1964 dodge 880 bolt pattern?
Old Apr 27, 2010 | 09:22 PM
scott2683's Avatar
So if I am measuring right, I believe my bolt pattern is 5-4 1/4 does that sounds right to you guys? I know typically dodge small bolt pattern is 5-4 1/2. Are wheels for this car going to be hard to find?
Old Apr 28, 2010 | 07:25 AM
MrOldart2U's Avatar
Yes that is the correct measurement, and no wheels are easy to find for that pattern, as the Mopar trucks, Mopar cars, Ford cars all use the same bolt pattern.
Old Apr 28, 2010 | 09:54 AM
scott2683's Avatar
Thanks for the advice, I will start looking a little harder for some 4 1/4 bolt pattern wheels!
Old May 2, 2010 | 11:25 AM
scott2683's Avatar
So I did some homework and I was measuring wrong
On a 5 lug car you measure from the middle of one lug skip one and measure to the BACK side of the next. So this makes my car a 4.5 not a 4.25 lug pattern?
Old May 2, 2010 | 08:27 PM
67gtxclone's Avatar
As far as I know, there are two bolt patterns, 5 on 4.0 which is on the smaller cars such as A body's, and 5 on 4.5 for the larger cars. No 4.25 that I am aware of. My B body has the 5 on 4.5.
Old May 2, 2010 | 09:12 PM
blue 68 gts's Avatar
As 67GtxClone said, I only know of 5 - 4 1/2, and 5 - 4.
I always measure from center to center, but i recently learned the "true" way is to measure from the middle to the end of the other side.
Old May 3, 2010 | 06:31 PM
scott2683's Avatar
Thanks for the help, I was under the impression that you measured center to center as well, So I do have a 4.5 bolt pattern if I measure center to back, which is nice knowing cause wheels are going to be a lot easier to find!
kmn5
May 19, 2021 04:18 PM
scott2683
Apr 6, 2013 08:25 PM
scott2683
Dec 12, 2011 09:17 AM
scott2683
Jun 6, 2011 12:38 PM
Barracuda64
Oct 31, 2010 12:53 PM
