1967 440 engine question.
Old Nov 15, 2012 | 07:52 AM
Younggun's Avatar
I found a guy who is selling a 1967 440 paired with the original 727. It came off a motorhome. My question is, are the motorhome engines the same used in the cars? Is there a difference in compression etc...
Old Nov 15, 2012 | 12:23 PM
Yes and No. Maybe 1/2 point lower. It depends on the heads some have the water pump mounted up hi to the heads which would have to be changed along with the heads them self, and probably the oil pan. The trans It depends Some of the bigger motor homes use a HD version of the 727 called a load flight ? It is physically larger. SO you need to see pictures. Could be a good deal or a bucket of bolts
71RR08
May 27, 2016 03:34 AM
rockinhlabs
Aug 29, 2012 10:15 AM
timmymacnj
May 20, 2010 09:37 AM
carlosg7915
Feb 20, 2010 10:51 AM
Rico1969
Jun 5, 2009 03:14 PM
