1974 dodge dart sport
Old Mar 24, 2010 | 11:41 AM
defeatedsanity's Avatar
Junior Member
ok so i have a 1974 dodge dart sport. it was a 225 slant six. had the engine and tranny pulled. purchased a 318 and a 727. bought some cheap motor mounts at an autoparts store. tried to put the engine and transmission together and the are a no match. tried to just put the engine in the body. no go. so i look at the engine casting numbers and cant figure out what any of it means. so do i need a new frame for the engine. or can i buy some mounts that will fit the old 225 slot. then how do i know what 727 i have and what 727 i need.
the engine came out of an 70s or 80s dodge truck.
i dunno where the trans came out of.
so will any of this work at all or am i wasting my time?
Old Mar 24, 2010 | 03:44 PM
mopardrt's Avatar
your going to need a v8 K frame
Old Mar 24, 2010 | 03:58 PM
SPICOLIE203's Avatar
As far a the tranny and the motor mounting up together do you have the flex plate on the back of the motor and the torque converter on the transmission, or is it that the bell housing does not even match up to the motor?
Old Mar 24, 2010 | 04:57 PM
Crazy4Carz.Com's Avatar
If people don't know the answer don't give the wrong one.
There is a company Schumacher that has the conversion mounts you need. The 727 came in both a big block version and a small block version, they do not interchange. Get a small block 727 and a set of correct mounts and it will drop right into place.
Old Mar 25, 2010 | 12:21 PM
mopardrt's Avatar
or..... just put a v8 K frame in it. no need to be like that crazy car
Old Mar 25, 2010 | 01:21 PM
is there a disadvantaged to still having the other k-frame when you put a 440 in?
strength wise?
Old Mar 26, 2010 | 03:57 AM
strength wise?
Nope.
Old Mar 27, 2010 | 10:19 PM
1966sportfury's Avatar
A.K.A Bob Dodge
all k member used the same guage and same size. strenght wouldnt be an issue. and replacing the k member is just a lot of work that doesnt need to be done.
TwistedWrenches
May 24, 2018 07:20 PM
dpmalibu
Sep 14, 2012 06:30 AM
dpmalibu
Jun 17, 2012 08:16 PM
howardl21
Aug 31, 2009 07:12 PM
TwistedWrenches
Mar 4, 2009 01:48 PM
