1977 440 oil pump removal
Old Jun 2, 2011 | 12:45 PM
69POLARA383's Avatar
First time tearing into one, bolts are removed but still cant get the pump to budge. It is painted over and gasket is probably helping a bit but I just don't want to yank and pull on this thing. Anyone have any suggetions?
Old Jun 2, 2011 | 10:16 PM
Why do you need to remove the oil pump ?? Put the old filter on it and give it a few wackes with a hammer
Old Jun 3, 2011 | 06:36 AM
Its a standard volume pump, I have a Melling HV pump. Thanks for the tip though
Old Jun 3, 2011 | 06:54 AM
got it off...it was actually a high pressure pump...Still replaced it with the new high volume. Anyone have two cents about which is better? I figured more volume better than more pressure
Old Jun 3, 2011 | 10:53 AM
There is a concern of mine with your HV pump...it pumps more oil for sure...do you have an extra 3 quarts of oil for it....meaning that at high rpm you can drain your oil pan while you wait for all of the oil on top of the motor to drain back down to the pan....HV pump usually requires an 8 quart pan....just M2C
Old Jun 3, 2011 | 11:49 AM
Yes, thanks for the input. I do have the 8qt pan with the hemi 1/2 pick up.
Old Jun 3, 2011 | 07:44 PM
scotts74birds's Avatar
Interesting take! I've always wondered about the hi-volume vs hi-pressure paradox!
Old Jun 3, 2011 | 08:44 PM
I sucked the pan dry with one on a 360. Lifters were noisy on the return road and the oil pressure was never the same Ended up breaking the crank, I thing it was due to flex from excess brg clearances
Old Jul 17, 2016 | 02:26 PM
barius's Avatar
How did you get it off? I'm struggling with the same issue. Pump stuck on block.
Leadsled
Jan 23, 2012 08:12 AM
dzltd02
Oct 28, 2008 08:25 AM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:34 PM
