1977 440 oil pump removal
First time tearing into one, bolts are removed but still cant get the pump to budge. It is painted over and gasket is probably helping a bit but I just don't want to yank and pull on this thing. Anyone have any suggetions?
There is a concern of mine with your HV pump...it pumps more oil for sure...do you have an extra 3 quarts of oil for it....meaning that at high rpm you can drain your oil pan while you wait for all of the oil on top of the motor to drain back down to the pan....HV pump usually requires an 8 quart pan....just M2C
How did you get it off? I'm struggling with the same issue. Pump stuck on block.
dzltd02
Oct 28, 2008 08:25 AM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:45 PM
robertoil
Jan 25, 2008 05:34 PM
