I have a 98 dodge B3500 maxi van extended with 5.9L it has 4000lb front axle, 392 gear. Was wanting to see if someone might know about the freeze plugs on this. I have 6 freeze plugs but no luck finding ones that fit they are bigger than the ones the parts store has for the 360 V8. It looks like from the factory they used a 360V8 motor an put a V10 bottom end on it. Mine has the high volume oil pump on it. Here is the numbers that are under the hood was wanting to see if someone can tell me something about this motor.
ok will check it out. An could the problem be were it has a high volume oil pump on it something was changed from the factory? The numbers for the 5.9L WCRXTO5.9AB1 & WCRXED174GEH what do those numbers mean?
I would not think so.....
Those look like the stickers on like the valve cover at the asm. line... im not inyo decoding that stuff.... maybe try AllPar Mopar.com and see you you find what your looking for...
