1998 Dodge B3500 Maxi
Old Aug 22, 2020 | 10:05 PM
Calvin Mossjr's Avatar
I have a 98 dodge B3500 maxi van extended with 5.9L it has 4000lb front axle, 392 gear. Was wanting to see if someone might know about the freeze plugs on this. I have 6 freeze plugs but no luck finding ones that fit they are bigger than the ones the parts store has for the 360 V8. It looks like from the factory they used a 360V8 motor an put a V10 bottom end on it. Mine has the high volume oil pump on it. Here is the numbers that are under the hood was wanting to see if someone can tell me something about this motor.
Old Aug 23, 2020 | 06:01 AM
Check Dorman Products>>>> V8 - 5.9 (360 CID) 2003-93 Engine Kit - 557-079 - - - 2003-93 Block - 1-1/4" SC 1 555-024 565-024 568-007 570-006 2003-93 Block - 1-11/16" AR 555-151 - - - 2003-93 Block - 1-41/64" 9 555-149 - - -
Old Aug 23, 2020 | 06:14 AM
ok will check it out. An could the problem be were it has a high volume oil pump on it something was changed from the factory? The numbers for the 5.9L WCRXTO5.9AB1 & WCRXED174GEH what do those numbers mean?
Old Aug 23, 2020 | 03:25 PM
I would not think so.....
Those look like the stickers on like the valve cover at the asm. line... im not inyo decoding that stuff.... maybe try AllPar Mopar.com and see you you find what your looking for...
Old Aug 23, 2020 | 03:27 PM
ok thanks
mdonalds201
Apr 15, 2019 12:58 PM
1 Bad Mirada
Sep 3, 2012 02:11 PM
Apollo
Dec 8, 2010 05:34 AM
birds
Mar 7, 2010 08:28 AM
