318 Engine upgrade... please help
Old Mar 25, 2008 | 11:22 AM
Some ramblings from the west
Your poor mileage figures are not going to be solved my major engine surgury. While increased compression ratio may help mileage and power somewhat, any gains well be offset by the requirement you have created to use good quality (premium) fuel, and the fact that "pinging" (knock or detonation) will require timing to be retarded.
Frankly, if you mileage is this bad now, it's because of some fault with the present engine, such as:
mechanical issues, difficult to guess
worn camshaft
improper cam timing
improper carburetion/ injection
improper spark advance
poor spark voltage, worn plugs, cap, wires, etc.
You can probably gain more "performance per price" by going to a different camshaft than by spending money on crank, pistons, etc.
(In the U.S. after somewhere around 1973 or so, many cars had screwed up camshaft timing, that is, the factory "smog" cams were retarded BY THE FACTORY. The only way to cure this to "pre smog" conditions is to either replace the cam with an aftermarket product, or by buying special timing drive sets that allow cam timing to be changed)
Old Sep 14, 2010 | 01:04 PM
Originally Posted by krislou80
Compression ratio is a commonly used term for internal combustion engine piston/cylinder compression and file compression. Ratios differ depending on the type of engine or the type of file being compressed.In file compression, 7zip has the highest compression ratio.my friend says that if you want to perform your air filter at best. You should used aem air air filter recharge kit. It will boost up your horsepower and increase your torque.
dead-post
please check the date of the previous posts
Old Nov 2, 2010 | 09:19 PM
alelogman's Avatar
Originally Posted by 69 Mopar Maniac
You can get a complete service manual from Mopar on CD. I strongly suggest you use the internet to source your parts and there are millions of 318's out there and parts as well.
It was one of Chyrslers best built engine and they put it in everthing.
Bringing up the compression is as easy as 1-2-3;...
I googled and it showed me thousands of records not good on online research so gave up after an hour but your post helped me solve some things. Thanks for the tips.
cudaracer
May 25, 2010 08:40 AM
45target
Dec 28, 2009 08:59 PM
crwchf16
Sep 22, 2009 08:49 AM
68camperspecial
Sep 18, 2009 12:45 PM
ProEmaster
Jun 6, 2007 11:31 AM
