413 or 383
Guest
Posts: n/a
413 or 383
i might buy a 68 monaco with a 383, or a 62 new yorker with a 413, I know they are about the same thing but is one better with stronger parts??
is the compression the same?? both are 4 barrel motors, and are the 727s the same or are the older like 62 models stronger?
I'm not intimately familiar with the old New Yorkers, but the older transmissions had the wierd old U joint on the rear of the trans, and I cannot for the life of me remember what they are called. Not desirable
Furthermore, the early models had the tapered rear axles, which aside from being weaker, and more difficult to get parts for, require a huge big puller to remove the rear hubs.
I'd buy the '68 if it were me
Guest
Posts: n/a
they used them in the c bodies of the sixty's not sure bout the late fifty's but i do now they were in the sixty's the new yorker, and the imperial both had these for a while those are two cars that came to mind for me there are others but can't think of any right of the bat. Anybody else knows of any other ones?
(There's a certain amount of poignant thoughts in the old Beach Boys tune "Shutdown")
http://www.lyricsfreak.com/b/beach+b..._20013813.html
While the all-out 413's were pretty torquey, those manifolds were not known for "top end"
However, they were pretty much the ancestor of the famous 426 max wedge:
http://www.fortunecity.com/silversto.../45/wedge2.htm
Guest
Posts: n/a
383 or 413
go with the 383. parts for the 413 are hard to come by and very expensive compared to the 383. the 413 was used in c-bodies from 1959 through 1965, when they were replace by the 440. the transmission in the 62 is also much more difficult to work with on a swap.
Guest
Posts: n/a
Parts for a 413 aren't scarce up here ! ...and the normal cast pistons give a better compression ratio than the 383.
Guest
Posts: n/a
413 vs 383
I was always told by older MoPar guys that the 413 is a longer stroke engine than the 383 so consider that for what you are installing. Are you looking for long term power or for quicker acceleration?
Given the weight of your body and its use, maybe the 383 might be better. If you were doing a truck, I'd say go with the 413 and a 727B with a Dana 60 rear axle. But that's my 2 cents, I'm a diesel guy
Guest
Posts: n/a
Go with the 383 parts new and used are much more readily available. Also, the 383's came stock with steel cranks but I'm not sure about the 413's.
The 383 would probably bring up the value of your care substantially but if you are looking for a rock solid block to punch out up to .080 look for a newer 400. Some came with steel cranks but most with a really beefy forged crank externally balanced.
So for value and tradition a 383 or for power and torque a 400. I have and still run both by the way!
labradorian70
Sep 24, 2014 09:44 AM
poolinstaller
Oct 27, 2007 07:34 AM
