440 engines.. how much power..?
Old Jan 19, 2009 | 02:37 PM
  #31
Polaradude's Avatar
If it were me, I would de-code the engines I had already, block, heads etc, if you have a virgin stock bore block why not build that one ? Just a thought bro.
Old Jan 19, 2009 | 04:40 PM
  #33
Polaradude's Avatar
Hey Joe, I think your two engines are the same. You said that the second one reads 7I 440-E, but I think its probably a T like the first one. The 7 T is 1977, 440 ci, and the E denotes a cast crank. Hope I helped a little. Also the T indicates the Trenton Plant.
The 3830733 is an intake that was produced from 74-76.
Your head #'s will be on the head in between valve springs, you'll have to remove valve covers, let me know if i can help.
Old Jan 19, 2009 | 05:11 PM
  #35
Polaradude's Avatar
I would say they are both 77 blocks, if they were 78, it would have 8T first.
The casting # 4006630 is any number of 440 blocks produced from 75-78
Old Jan 20, 2009 | 05:15 PM
  #37
challenger's Avatar
hey joe66 been off puter for a few but that kit you are showing seems really nice but didnt see anywheres where they say to use that year motors you have but go ahead and ask them what they think but like i said if it were me i would not use that year motor if your looking for a monster motor , a thin wall is a thin wall no two ways around it but some people do get lucky and im sure they last for them but no way are they running 650+ hp but if they are i guess they have proved me and chrysler wrong as they tell you time and time again not to use a late 76-77-78 block for a bracket race or high hp engines nor go over .020 bore but hey its not my money right and if anyone has a motor with that much hp well im proud cause ive always said mopar is the best hehehe and that they are tough ----- check with them (440 source) and see what they say for the heck of it ...
Old Jan 21, 2009 | 01:24 PM
  #38
if the block was made in 77, it probably wouldnt have been used until 78
Tom T2
Aug 23, 2015 07:21 PM
ChrisG
Oct 5, 2012 11:43 AM
Greaser
Aug 21, 2012 08:04 AM
rcknrolfender79
May 15, 2010 11:35 AM
Buffalojoe426
May 14, 2010 03:42 AM
