5.7 hemi torq specs
On my 2006 5.7 hemi.......
Intake bolts are 105inch lbs, start from the middle bolts towards the outside in a criss cross pattern
Head bolts are done in either two steps or three depending on the size of the bolt.
and because mine are metric.....
For M-12 bolts Step one is 25Ft lbs
Step two is 40 Ft lbs
Step three Turn 90* (deg)
For M-8 bolts Step one is 15Ft lbs
Step two is 25Ft lbs
This should work for newer model years as long as yours is NOT pre 1980 I can look up your spec if you give me a year.
ralphr87
Sep 25, 2012 09:53 PM
