5.7 hemi torq specs
Old May 13, 2010 | 08:22 PM
smackhonda's Avatar
5.7 hemi torq specs
any one know the torq specs for the cylinder head and intake manifold for a 5.7 hemi off the top of your head?
Old May 14, 2010 | 04:35 AM
sweeperking's Avatar
On my 2006 5.7 hemi.......
Intake bolts are 105inch lbs, start from the middle bolts towards the outside in a criss cross pattern
Head bolts are done in either two steps or three depending on the size of the bolt.
and because mine are metric.....
For M-12 bolts Step one is 25Ft lbs
Step two is 40 Ft lbs
Step three Turn 90* (deg)
For M-8 bolts Step one is 15Ft lbs
Step two is 25Ft lbs
This should work for newer model years as long as yours is NOT pre 1980 I can look up your spec if you give me a year.
Old May 14, 2010 | 04:56 AM
smackhonda's Avatar
thanks man. I got a 06 hemi so that should work fine. also it doesnt look like there is any adjustment for the valve lash on these rocker arms, are they just pre set. thanks again
Old May 14, 2010 | 07:01 AM
Rocker arm bolts are 195 in lbs
Throttle body to intake mount bolts are 105 in lbs
Hope this helps
Old May 5, 2017 | 08:03 PM
Bing's Avatar
Hello Fella's does anyone have the torque specs for a 2010 5.7 hemi head? I'm in the middle of a head job and could use them. Thanks in advance...
ralphr87
Sep 25, 2012 09:53 PM
68 Sat
Nov 7, 2009 07:14 PM
Zach8200
Jan 10, 2009 07:35 PM
got2mopars
Sep 22, 2007 05:44 PM
resbum
Mar 17, 2007 09:12 PM
