65 FURY CARB CARZY ??
Old Dec 11, 2011 | 06:05 PM
jack65fury's Avatar
HELLO, NEW HERE. HAVE 65 FURY II 318 . JUST 54K, MILES. COMPLETED MANY NEW PARTS, PLUG WIRES , FUEL FILTER , POINTS ,DISTRIBITOR, COIL, ALTERNATOR, WATER PUMP, BELTS, HOSES, ETC. SHE JUST HAD CARB KIT. NOW SHE STOPS RUNNING WHEN IN GEAR, RUNS FINE IN PARK SHADE TREE GUY, ADJUSTED MY CARB FLOAT, SCREWED IT UP. I HAVE TURNED IDLE SCREW , AND TRIED TO ADJUST AIR /FUEL MIX. WHAT SHOULD I DO FIRST? THANKS FOR HELPING A ROOKIE
Old Dec 11, 2011 | 07:05 PM
Get you a vacuum gauge...put it on the manifold vacuum source and try to adjust the idle mixture screws for the highest vacuum you can get. 10-14 inches of vacuum are good. Too low and the motor will die when you put it in gear.
Old Dec 12, 2011 | 03:19 PM
Make sure the vacuum lines are hooked up -- no vacuum leaks !!!
northcoasttip
Sep 26, 2011 11:23 PM
kistlerjm9
Jun 9, 2011 07:31 PM
furyaboveall
May 6, 2011 01:46 AM
