66 Fury windshield
Old Oct 3, 2023 | 05:07 PM
old rat 48's Avatar
Question 66 Fury windshield
Have new rubber to reinstall my windshield for a 66 Fury III hard top. The bottom portion is different than any I have installed. Anybody point me in the right direction as to how I seal the bottom part. Nasty wet weather coming and need it back in. Thanks
Old Oct 3, 2023 | 10:41 PM
What vehicle are you working on?🤪
Old Oct 4, 2023 | 04:38 AM
old rat 48's Avatar
As stated in topic a 1966 Fury Hardtop.
Old Oct 9, 2023 | 05:26 PM
I’ve never worked on one specifically but if it’s a rubber gasket, it needs a pinch weld to hold on to. I usually start at the bottom and rope it in.
Old Oct 9, 2023 | 05:48 PM
old rat 48's Avatar
I've done quite a few rubber gasket windows but the bottom of these lays flat on the cowl.
Old Oct 10, 2023 | 02:22 PM
If that’s the case then I would use a bead of urethane on the cowl and pull the rest in. I can’t say in fifty years of working on this old junk I’ve ever run across this but something needs to hold the glass down. Does it have a large molding across the lower edge?
pictures would help.
Old Oct 14, 2023 | 04:56 AM
old rat 48's Avatar
It does have a large flat lip on bottom. I have put sealer on it and hosed it down and appears to be dry.
Old May 16, 2026 | 09:58 PM
zunepuh's Avatar
Originally Posted by old rat 48
Have new rubber to reinstall my windshield for a 66 Fury III hard top. The bottom portion is different than any I have installed. While researching Polaris Ranger windshield options I came across some useful sealing tips that got me thinking about my own project. Anybody point me in the right direction as to how I seal the bottom part. Nasty wet weather coming and need it back in. Thanks
The bottom of the 66 Fury III hardtop has a secondary inner lip that tucks into a recessed pinch weld. Apply butyl rope sealant into the rubber channel before setting the glass, tuck that inner lip over the pinch weld using a nylon pull cord from inside the car, and pack the bottom corners with windshield urethane since that is where leaks start. A soapy water spray helps slide the rubber into place without tearing it. Once done, run a bead of silicone along the interior garnish moulding at the bottom for extra insurance before the rain hits. Good luck!
chrome
Jun 28, 2015 09:31 AM
ShadeTreeMachanic93
May 22, 2015 07:54 AM
hemiowner
Jan 31, 2012 04:35 PM
destro360
May 3, 2011 05:51 PM
scotts74birds
Jul 4, 2009 04:54 PM
