69 GTX Need vin/fender tag/motor# help
Old Nov 20, 2008 | 12:31 PM
Zach8200's Avatar
try the roadrunnersite.com
Old Nov 21, 2008 | 03:07 AM
BuckNeccid's Avatar
Frankie, look on the side of the block, right against the oil pan mounting flange. Passenger's side. There will be a machined pad maybe 1/2" high. If it's a numbers matching engine, the sequence number of the car will be stamped there. The sequence number will also be stamped in about the same place on the tranny.
Old Nov 21, 2008 | 07:22 PM
65Satellite's Avatar
Junior Member
That is the correct place, however it is the VIN,not the sequence number
Old Nov 22, 2008 | 04:47 AM
BuckNeccid's Avatar
Thanks Satellite, You're right. I got it confused with the other stampings on the sheet metal.
Old Nov 22, 2008 | 12:57 PM
challenger's Avatar
Mopar VIN Decoder Mopar Muscle Cars Mopar Casting Numbers - MyMopar.com - Mopar Part Numners Mopar Codes - MyMopar.com - Mopar Part Numbers you should find everything you want to know about your car from one of these sites as they have # and codes from the heads to your taillight
Old Nov 24, 2008 | 11:42 AM
BuckNeccid's Avatar
If it's a 440,426, or 413 look at the front of the block, in front of the intake. There will be a machined pad cast into the block with a letter and number. A 69 440 will read something like E 440 (and possibly HP) if it's a b block, then there will no pad there, but under the passenger side head, there will be a machined pad with the motor size. If the distributor is in the rear of the engine, you have a small block.
Old Nov 25, 2008 | 04:40 PM
rr69half6bbl's Avatar
Okay I can tell you on the fender tag, that the top line first 1, v-21, thats hood performance treatment. means that it had the bloack hood stripes. next to bottom line. the a-4,a-4 means the paint code, platinum silver. exterior, roof, then later down that row, another a-4, means the int. color. man thats a cool car. I havent heard of or seen to many a-4 cars, let alone triple silver. id spend the 30 bucks and send a rubbing of the tag to galen and have him document it. even if it isnt a #`s car, thats cool.congrats.
RandyP63
Feb 6, 2011 12:13 PM
crewcab4x4x4
Jan 15, 2011 01:12 PM
67 Fury
Feb 12, 2010 08:17 PM
MarkyMark12345
Mar 16, 2009 01:02 PM
raynor racing
Mar 3, 2008 11:05 AM
