72 Cuda Leaf Springs - Help!
Old Jul 25, 2010 | 02:43 PM
CudaRescue's Avatar
Junior Member
Exclamation 72 Cuda Leaf Springs - Help!
My Cuda has a 44.5" centers distance between the front hangers (for the rear leaf springs). My 8-3/4 axle has 44.5" between the perches. At the rear hangers (shackles) the centers distance is 47.5". This isn't making sense to me and I can't get the springs on. Do I need offset shackles? Do I need to move the perches out? How was factory set up?
The axle I don't think is the original. I went to rebuild the brakes and 1972 parts were not right. Turned out 1969 parts were right (for adjuster and spring kits).
Do the leaf springs sit at an angle thus the perches should be at 46" centers (or something close)?
Thx for any help!
Old Jul 25, 2010 | 03:00 PM
Crazy4Carz.Com's Avatar
Everything you have is correct. The E body springs are installed at an angle. They will go, just work with it.
Old Jul 26, 2010 | 07:13 PM
CudaRescue's Avatar
Junior Member
Thumbs up
I'll try again. Think I'll float axle this time instead of doing one side. Thanks!
CudaRescue
Sep 1, 2010 09:35 PM
rr69half6bbl
Jan 25, 2009 10:11 AM
trdavey
May 9, 2008 05:56 PM
89klr250
Mar 2, 2008 06:09 AM
Gator
Apr 26, 2007 07:10 PM
