'74 Charger 318 coolant leak, milky oil
Old Jul 29, 2012 | 04:10 PM
Rumblefish318's Avatar
I bought this car 1 month ago. It had sat for 5 years. I initially changed the oil and it look like there was 5-6 quarts of brownish, milky oil that drained out. I changed the oil + filter and now I'm getting milky oil again along with white foam under the oil cap. I did a compression check on all 8 cylinders and they were all between 132 and 150 psi. Do these engines have problems with the blocks, heads cracking? It sounds like a head gasket, but wouldn't that show a low cylinder compression? I will probably pull the motor and rebuild starting with a block hot tank and magnaflux. IF I do pull the heads, will I be able to see evidence of it a blown head gasket?
www.1974dodgecharger.blogspot.com
Old Jul 29, 2012 | 08:44 PM
Did it have anti freeze in it ??? IF not I would check the timing cover first..
for corrosion- could allow water into the oil pan. Could be as you suggested - A head gasket
Old Jul 31, 2012 | 06:14 AM
Gorts 5th's Avatar
yes ive had a leak at the timing cover check those bolts
hckrphil
Jun 17, 2014 09:53 AM
pjjaramillo
Aug 30, 2010 11:22 AM
MarkyMark12345
Jan 31, 2010 09:30 AM
MarkyMark12345
Apr 10, 2009 06:43 PM
dzltd02
Oct 28, 2008 08:25 AM
