74 Dodge Charger 318/auto/column shifter linkage question
Old Jul 17, 2013 | 04:31 PM
Rumblefish318's Avatar
What is supposed to attach to this bracket? Am I missing a part? I am ordering the correct bushings for the linkage brackets. TY.
Attached Thumbnails 74 Dodge Charger 318/auto/column shifter linkage question-011.jpg   74 Dodge Charger 318/auto/column shifter linkage question-004.jpg   74 Dodge Charger 318/auto/column shifter linkage question-005.jpg
Old Jul 17, 2013 | 05:46 PM
The linkage is totally hooked up wrong.. The stud hole in the bell housing should have a stud with a swivel bracket for the kick down, depending on style. The linkage needs to be above the torsion bar The bracket needs to be rotated 180* on the frame - also looks like someone tried to bend it streight..
Old Jul 17, 2013 | 05:55 PM
This car was a nightmare basket case when I bought it. Doesn't surprise me at all that it's hooked up wrong. I am ordering some new bushings and will consult Haynes Repair Manual and other sources. Hopefully, the info you gave me will start to make sense and become clear. TY TNLynn.
Old Jul 17, 2013 | 06:18 PM
Here's a bunch, didn't look close enough to see if one is yours though.
http://www.moparts.org/Tech/Archive/auto/35.html
Old Jul 18, 2013 | 03:20 AM
One end of the cross shaft fits into the trans bracket (ORANGE BUSHING SHOWN IN THE TRANS PIX) The other end fits into the bracket that bolts to the frame- the bracket should have an index pin. then one rod goes from the bracket arm to the column other arm goes to the trans if that makes sense ?
The Fury 8 pix 8 for the trans kickdown ???
Old Jul 18, 2013 | 10:14 AM
Coronet 500 hundred it the nail on the head for piture # 1
Looks like you missing some of the linkage there for the lick down.
Piture 2&3 are just Shifter shafts and it looks like all you need are some new bushings...
70Coronet
Sep 19, 2012 07:28 PM
70Coronet
Apr 20, 2012 04:28 PM
tripnip
Sep 14, 2011 11:29 PM
soundhd
Oct 13, 2010 08:33 PM
fivepoint
May 20, 2010 09:50 AM
