AC not blowing cold..
You need to have a shop pull vacuum and see if it holds. if it does see if what they pulled out is the same amount that is suppose to be in there. If not and it doesn't hold vacuum, you probaby have a leak. Need to add dye to the system, let it cycle for about 10-15 minutes, take the yellow light and glass and start looking.
Is your compressor cycling on and off?
Dave E
13
11-01-2015 10:46 AM
retired
07-18-2012 05:57 PM
