AC possible or not
Old Jun 1, 2013 | 07:01 AM
JPS's Avatar
JPS
AC possible or not
I just picked up a 74 cuda. E body. it has a 440 in it from a 71 cuda. the 74 was an AC equipped car. The previous owner never put it back in when he installed the BB. Will I be able to put the AC back in with the bigger engine. Looking for any input before I spend the money on a new AC unit.
Old Jun 1, 2013 | 07:41 AM
I guess the answer is a qualified "yes" depending on how much you want to spend.
Did the previous owner pull all of the AC components out of the interior? If so, you'll have quite a job rounding up the entire interior heater/ AC box, controls, vacuum lines, and ducting.
If that's still all there, and the evap has been kept clean, and does not leak, replacing the underhood stuff is not really that big a deal.
Old Jun 1, 2013 | 08:00 AM
Vintage air to the rescue.
Old Jun 1, 2013 | 08:31 AM
Shrug's Avatar
Do NOT waste your money on Vintage Air.
http://rainbowproductsonline.com/ has the exact same components for about 30% less!
I have put Rainbow Air units in several of my cars.
This kit for $699 is 300 bucks more at Vintage
http://rainbowproductsonline.com/ind...=105&Itemid=32
Old Jun 15, 2013 | 03:53 PM
Buy the kit ! You can spend just as much or more trying to fix the original system. You will end up with a poor 70's system after a required switch to current R134
GO NEW.. $699? Complete kit all new parts designed for R134 $1200
stickshifted
Nov 6, 2010 08:56 PM
jvfante
Apr 28, 2009 10:55 AM
stickshifted
Apr 8, 2009 04:25 PM
jonny5
Feb 25, 2007 04:03 PM
