Advice on pulling a 440
Old 01-10-2015 | 11:50 AM
Kevin71's Avatar
Will a plate that fits over the carb hole on the intake manifold work for pulling a 440.
Old 01-10-2015 | 12:37 PM
fivepoint's Avatar
It worked for me. I even did it on an aluminum intake. I was concerned that the threads would pull out but it worked fine.
Old 01-10-2015 | 01:00 PM
Just don't try removing the converter with the engine.. Disconnect it first..
Old 01-10-2015 | 01:28 PM
Kevin71's Avatar
tried a load equalizer bar
Tried a load equalizer bar that bolt to the four corners of the intake. Pulled two of the bolts out when I tried to raise the motor. The heads are aluminum. It is a 5 speed. so don't have a converter on it. I think the trans is not able to come up because the rear of it is pushed all the way to the floor on tail end to get drive line angles right.
Old 01-10-2015 | 06:12 PM
moe7404's Avatar
i have pulled many early 331, 354, 392 hemis with a carb plate. no trouble. the 392 DOES weight 800-900 lbs. with a cast iron torqueflight its more like 1000-1100 lbs. the 392 heads are 45 lbs ea bare. the rocker Stantons are 30 each.
Kevin71 (01-11-2015)
Old 01-11-2015 | 11:18 AM
Make sure you have everything disconnected... That sucks you pulled the treads...
Old 01-11-2015 | 03:53 PM
If it is real difficult you might remove the trans first and then the engine, The dowel pins in the block may be frozen ? Just double check that everything is disconnected...
Old 01-11-2015 | 08:06 PM
moe7404's Avatar
block dowel pins ? yep my dad bought a 300 J that the first owner put a 500 in max engine. by using a 440 bare block from chrysler. but for got the dowel pins. the flex plate ripped apart as we drove it home. the first owner had that happen to him. he thought it was from the tons of power. SO dont for get that chrysler does NOT put the dowel pins in a factory bare block. so we had TONS of fun blowing away EVERY ford we came across on the street.
Skynyrd
05-20-2015 05:27 AM
Outsider
11-23-2014 09:40 PM
Joseph McClure
02-15-2014 02:37 AM
74Runneer
03-02-2013 07:16 AM
64fury
05-14-2010 09:49 AM
