Any one Painted their Engine Bay..
Old 03-04-2013 | 06:47 AM
raycan2's Avatar
I started working on the engine bay and gonna paint it, I have some time till the engine is done...It a lot of fun but A LOT of work,,,,,My plan is paint it now that way when I paint the car I don't have to pull it out.
Old 03-04-2013 | 06:58 AM
Gorts 5th's Avatar
Smile
i have painted engine bays before.
i would recommend a gravity fed cup gun set the air pressure low and the volume of primer and paint low, light coats there are many areas inside that bay for runs to appear. make sure its clean and oil free.
Old 03-04-2013 | 07:37 AM
raycan2's Avatar
Do I have to take the paint all the way down to the metal? I mean I already started but was that a have to?
Old 03-04-2013 | 10:40 AM
pro-tech's Avatar
Use a media blaster it takes it to bare metal real quick. There's not alot of paint from the factory in the engie compartment. Then opoxy primer and then the color you want use a low pressure gravity feed gun. $20 at harbor frieght.If I did it with no runs then so can you it is a piece of cake
Old 03-04-2013 | 04:23 PM
Mr.4spd's Avatar
But should he use a gravity feed gun? I think he should use a gravity feed gun. Gravity feed gun.
Old 03-04-2013 | 07:36 PM
jacilynn_s's Avatar
Few things.
First and foremost do not worry about anything. Factory the bays were badly painted. Second there is junk for paint, unless you have some enamel laying around, its gonna rust no matter what you do. Thanks to the greenpeace a$$holes we have nothing to paint a car with anymore.
You would have been better off leaving the original enamel paint and cleaning it as best as you could before using modern primers and paint on it.
Old 03-05-2013 | 03:21 PM
pro-tech's Avatar
Mr.4sp yeah HVLP Gravity feed gun. Use acrylic enamal its the same as it was 30 yrs ago and is still avalable you have to finish it now you already have it down to bare metal in many places. What color are you painting it? and the car?
Old 03-05-2013 | 05:51 PM
Gorts 5th's Avatar
Smile
low presser when i painted they didn't have High volume low presser guns they just started introducing them into the industry we used old school high presser but dialed it down at the gun with a valve i use one today, watch it fall from the gun like little rain drops, flows out real nice, very easy to use, it's very forgiving, too a point! use light coats i like starting at the high points and the sharp edges and work out . Don't be afraid to adjust your fan size... test it on the masking paper on the windshield keep your flow rate low so as to avoid runs and wipe the crap out of the finished primer with silicone tar remover, also at the suppler. make sure there is no silicone around or you will get "fish eyes" in your paint.
follow the directions... get yourself a ratio stir stick it has the ratio scale on it you can get it at the local body shop supplier, it will ratio out the color the reducer the hardener.
Old 03-05-2013 | 06:21 PM
raycan2's Avatar
Pro Tech Iam thinking about going with Black on the inside of the engine bay and the out side going with a Sublime green...With the black hood
OldChargerGuy
12-03-2012 05:10 AM
northcoasttip
09-27-2011 05:11 PM
ngc414
07-15-2009 06:18 PM
Valcam
06-26-2009 01:51 PM
Jack Truneg
10-22-2008 01:56 PM
Quick Reply: Any one Painted their Engine Bay..
