Any one Painted their Engine Bay..
I started working on the engine bay and gonna paint it, I have some time till the engine is done...It a lot of fun but A LOT of work,,,,,My plan is paint it now that way when I paint the car I don't have to pull it out.
i have painted engine bays before.
i would recommend a gravity fed cup gun set the air pressure low and the volume of primer and paint low, light coats there are many areas inside that bay for runs to appear. make sure its clean and oil free.
Use a media blaster it takes it to bare metal real quick. There's not alot of paint from the factory in the engie compartment. Then opoxy primer and then the color you want use a low pressure gravity feed gun. $20 at harbor frieght.If I did it with no runs then so can you it is a piece of cake
Few things.
First and foremost do not worry about anything. Factory the bays were badly painted. Second there is junk for paint, unless you have some enamel laying around, its gonna rust no matter what you do. Thanks to the greenpeace a$$holes we have nothing to paint a car with anymore.
You would have been better off leaving the original enamel paint and cleaning it as best as you could before using modern primers and paint on it.
Mr.4sp yeah HVLP Gravity feed gun. Use acrylic enamal its the same as it was 30 yrs ago and is still avalable you have to finish it now you already have it down to bare metal in many places. What color are you painting it? and the car?
follow the directions... get yourself a ratio stir stick it has the ratio scale on it you can get it at the local body shop supplier, it will ratio out the color the reducer the hardener.
