Which is better????
Old Jun 21, 2010 | 04:40 PM
old tired rebel's Avatar
Which is better????
Which would be a better engine to build a stroker engine out of a 318 or a 400?
The car weighs in about 4000 lbs. and power everything. 1978 Cordoba
Old Jun 21, 2010 | 04:50 PM
1966sportfury's Avatar
A.K.A Bob Dodge
hands down the 400!
Old Jun 21, 2010 | 06:01 PM
blue 68 gts's Avatar
hands down the 400!
Uh, yep! 451 stroker!
Old Jun 22, 2010 | 04:07 AM
dodgenut7's Avatar
400 without a doubt
Old Jun 22, 2010 | 02:34 PM
def. the 400
Old Jun 22, 2010 | 05:54 PM
mopardrt's Avatar
400 with a 440 crank makes you a home built stroker
Old Jun 22, 2010 | 06:30 PM
A.K.A Bob Dodge
yeah then grind the block so the crank will clear then get rods made cuz the RB,s would be to long so would the B,s then get pistions made then you end up with a 444 (with a stock bore 400)
the kit would be cheaper
Old Jun 22, 2010 | 09:13 PM
mopardrt's Avatar
wohaa way to make me look like a TARD lol um i only play with small blocks I had been told it was easier then all that junk hmmmmm
Old Jun 22, 2010 | 09:26 PM
A.K.A Bob Dodge
i could be wrong, im sure the rods would be too long,, seems to me i measured it and the pistions would stick out past the top,
Old Jun 23, 2010 | 08:13 AM
Just check out http://www.440source.com/strokerkits.htm they make it easy with their kit they also have a new website that has all their products. I am thinking about going this route since everything has been designed to work together. I can get a complete 400 for $250, but I am going to try and get the whole car so I can have all the parts I need.
dodgenut7
Jun 29, 2011 07:09 PM
crwchf16
Dec 12, 2009 05:44 PM
Valcam
Jun 4, 2009 11:47 PM
Elmo
Sep 12, 2008 05:46 PM
Yorkie Mama
Apr 7, 2008 11:33 AM
